15 years agoVHDL timer
hi, how can I write a program for a timer which Measures a pulse width that represents of range.i'm using un ultrasonic sensor, The distance can be calculated using the scale factor of 147u...
13 years agoOk this is what I wrote in VHDL and when I run the code (in quartus II) I got success put when I go to the RTL viewer to draw the circuit I gut only the pin for input and output but when I do the same for AHDL code I have very big and different circuit.
library IEEE; use IEEE.STD_LOGIC_1164.all; entity two is Port ( clk : in std_logic; enl : in std_logic; second : out std_logic ); end two; architecture Timer of two is constant count : natural := 48000000; -- I used 24MHz clock begin process (clk, enl) variable count : natural range 0 to count; begin if (enl ='1') then if (count = 48000000) then count := 0 ; second <= '1'; else count := count+1; second <= '0'; end if ; second <= '0'; end if ; end process; end Timer;
