15 years agoVHDL std_logic_vector Comparisons
What's the best way to compare std_logic_vector 's to zero in VHDL? I don't want to use conversion functions, create a std_logic_vector of "0"s, or do element-by-element comparisons.
15 years ago --- Quote Start --- You can create a std_logic_vector of zeros using "others" that's nice. constant bus_width : integer := 32; signal my_signal : std_logic_vector(bus_width -1 downto 0); constant zeros : std_logic_vector(bus_width -1 downto 0); zeros <= (others => '0'); ... if (my_signal = zeros) then... This makes it a little cleaner. --- Quote End --- You cannot "assign" a constant, you can only initilise it at declaration. For the origional poster - Im on the opinion that its always best to write explicitly what you mean. So if you are checking that all bits in the bus are zero, then use the and_reduce, or when VHDL 2008 gets support, you can just write the following: if (and my_slv) then .... But if your std_logic_vector represents a number, compare it to the integer 0. if my_slv = std_logic_vector( to_unsigned(0, my_slv'length) ) then ... Now I know you said you didnt want to have type conversion functions, but this way shows to another engineer that your std_logic_vector represents an integer and not just a collection of bits. This would beg another question though - why are you using std_logic_vectors to represent integers?
