16 years agoVHDL starter/biginer
hello everyone i new in using modelsim xe iii/starter and have this project to start:
1. Write a VHDL description of an SR latch a. Use the characteristic equation b. Use logic gates c. Use a conditional assignment statement 2. A 4-bit magnitude comparator chip (http://focus.ti.com/lit/ds/symlink/sn74ls85.pdf) compares two 4-bit numbers and produces a three bit output. a. Write behavioral VHDL description for this comparator chip. b. Using structural VHDL, cascade two 4-bit chips to make an 8-bit magnitude comparator. Include block diagram. 3. The 74194 four-bit bidirectional shift register (http://focus.ti.com/lit/ds/symlink/cd74hc194.pdf) includes an asynchronous reset, parallel load and left/right shift. a. Write a behavioral VHDL model for the 74194. b. How can this be extended to an 8-bit shift register? Implement in VHDL. 4. Design a counter that repeatedly counts in the sequence: 0000, 0001, 0010, 0100, 1000, 0000, …. An asynchronous load input loads the counter with 0000.i need help for this project while in the mid-time i'm reading and getting familiar with the program...any help will be truly appreciated...
I can't help you...
--- Quote Start --- I am a beginner . Anynoe who has some materials? Could you send me some materials ? Thanks! Waiting for your reply --- Quote End --- u can start with RTL from Pong Chu or MIT press - Altera_Forum
Here are some links you can go through VHDL by examples.
http://esd.cs.ucr.edu/labs/tutorial/ http://www.seas.upenn.edu/~ese171/vhdl/vhdl_primer.html http://www.csit-sun.pub.ro/resources/vhdl/vhdl_book_html/
