15 years agoVHDL problem?
QUESTION: Develop a VHDL model for an accumulator that calculates the sum of a sequence of fixed-point numbers. Each input number is signed with 4 pre-binary-point and 12 post-binary-point bits....
15 years ago --- Quote Start --- based on code above,there is up until 20-bits,but on the DE2 usb blaster board,there is only enough for up until 10-bits.can i know how to re-make the code so it will synchronize with the pins available on the board? --- Quote End --- You can do this by passing first 10 bits during clock high and another 10 bits during clock low.
