18 years agovhdl problem for iir filter
hi: guys i have a problem makes me crazy. how to use vhdl codes to implement iir filter y(n)= 2cos(w)*y(n-1) - y(n-2) and the initial conditions is y(-1)=sin(w),y(-2)=sin(2w). which m...
18 years agoHello,
I can't indentify a filter, cause there is no signal input. If you are actually trying to design an oscillator, then you should probably choose a structure less sensitive to rounding errors or use an NCO instead. But apart from this consideration, the shown IIR structure can surely be synthesized in VHDL. I understand, that cos(w) is a constant that either can be calculated at compile time or loaded as a parameter (which is big difference for FPGA implementation), the same with the said initial values. Next you have to define a numeric format (probably signed) and a resolution. Then the algorithm can be build from a multiplier and a substractor megafunction or infered from HDL. Two registers are needed to store previous y(n). Basic operation can be evaluated also in a spreadsheet tool, e. g. Excel to study rounding error effects with different numerial resolution. Regards, Frank
