18 years ago
vhdl problem for iir filter
hi: guys
i have a problem makes me crazy.
how to use vhdl codes to implement iir filter
y(n)= 2cos(w)*y(n-1) - y(n-2)
and the initial conditions is y(-1)=sin(w),y(-2)=sin(2w).
which means i need output this filter every cycle calculation like following y(0),y(1)....
y(0)=2cos(w)*y(-1)-y(-2);
y(1)=2cos(w)*y(0)-y(-1);
i use a mac and a rounding operation to do it.
but its not work like i describe above.
how should i do. Am i need plus some selfcycle computation on testbench or on original filter codes. And how to plus it into this codes.
thanks
    sorry to Frank
    the forum can not attached the .rar files, so please show me your email address, i send it to you directly.
    to Frank:
    thank you pay attentation to my problem.
    yes, as you said i am doing a digital oscillator utilized a iir structure.
    you said i need two registers to store previous y(n). i show u my codes as attached, may be when u see my codes you can understand my problem totally.
    Please check out my codes, and give me some advise agian.
    Thank you
    I can't indentify a filter, cause there is no signal input. If you are actually trying to design an oscillator, then you should probably choose a structure less sensitive to rounding errors or use an NCO instead.
    But apart from this consideration, the shown IIR structure can surely be synthesized in VHDL. I understand, that cos(w) is a constant that either can be calculated at compile time or loaded as a parameter (which is big difference for FPGA implementation), the same with the said initial values. Next you have to define a numeric format (probably signed) and a resolution. Then the algorithm can be build from a multiplier and a substractor megafunction or infered from HDL. Two registers are needed to store previous y(n).
    Basic operation can be evaluated also in a spreadsheet tool, e. g. Excel to study rounding error effects with different numerial resolution.
    Frank
