16 years agoVHDL Package
Hi, Pardon me if this is not the right place to post this question. Just a simple one. Im not too sure about this package thingy in vhdl coding. How does it differ from creating a component and...
16 years agoYou could create a package of arithmetic functions, but you'd still have to call the functions inside a process, or another function. A package on its own is not synthesizable. Only processes produce gates and registers. But if the arithmatic was complicated in some way it may make the code more readable, so you could write this in your entity:
process(clk)
begin
if rising_edge(clk) then
output <= do_some_stuff(a, b);
end if;
end process;
you could create a component to do the arithmatic, but its no more or less benficial than just doing it in the same entity. Its down to personal preference and also whether it partitions the design into an easier to understand layout. At the end of the day, its the same gates and registers.
