16 years ago
VHDL For Altera De2 board normal text on LCD 16 x 2 help!!
I need help on displaying the "HITACHI " word on the altera DE2 lcd. the following is my codes.
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.all;
USE IEEE.STD_LOGIC_ARITH.all;
USE IEEE.STD_LOGIC_UNSIGNED.all;
entity hitachi is
port
reset,clk : in std_logic;
rs,rw,e,pwr,bkpwr : out std_logic;
data : out std_logic_vector(7 downto 0)
end hitachi;
architecture behv of hitachi is
type state_type is (wt,wt1,wt2,funcset,displayon,displayoff,displayclr,
entry,wrt,wrt1,wrt2,wrt3,wrt4,wrt5,wrt6,wrt7,entry1,wrt8,hm,hold);
signal state : state_type;
begin
pwr<='1';
bkpwr<='1';
rw<='0';
e <='1';
process(clk, reset)
begin
if reset = '0' then
state <= wt;
rs<='0';
data<= "00110000";
elsif rising_edge(clk) then
case state is
when wt =>
state<=wt1;
when wt1 =>
state<=wt2;
when wt2 =>
state<=funcset;
when funcset=>
rs<='0';
data<= X"30";
state<=displayoff;
when displayoff=>
rs<='0';
data<= X"08";
state<=displayon;
when displayon=>
rs<='0';
data<= X"0E";
state<=displayclr;
when displayclr=>
rs<='0';
data<= X"01";
state<=entry;
when entry=>
rs<='0';
data<= X"06";
state<=wrt;
when wrt=>
rs<='1';
data<= X"48";
state<=wrt1;
when wrt1=>
rs<='1';
data<= X"49";
state<=wrt2;
when wrt2=>
rs<='1';
data<= X"48";
state<=wrt3;
when wrt3=>
rs<='1';
data<= X"54";
state<=wrt4;
when wrt4=>
rs<='1';
data<= X"41";
state<=wrt5;
when wrt5=>
rs<='1';
data<= X"43";
state<=wrt6;
when wrt6=>
rs<='1';
data<= X"48";
state<=wrt7;
when wrt7=>
rs<='1';
data<= X"49";
state<=entry1;
when entry1=>
rs<='0';
data<= X"07";
state<=wrt8;
when wrt8=>
rs<='1';
data<= X"20";
state<=hm;
when hm=>
rs<='0';
data<= X"02";
state<=hold;
when hold=>
rs<='0';
state<=state;
end case;
end if;
end process;
end behv;
entity hitachi_top is port(
resetx,clkx : in std_logic;
rsx,rwx ,ex,pwrx,bkpwrx : out std_logic;
datax : out std_logic_vector(7 downto 0)
end hitachi_top;
architecture Behavioral of hitachi_top is
component hitachi port (
rs,rw ,e,pwr,bkpwr : out std_logic;
end component;
component div25 port (
clkf : in std_logic;
clk25 : out std_logic
end component;
signal clk: std_logic;
begin
l1: hitachi port map (reset=>resetx,clk=> clk, rs=>rsx, rw=>rwx,
e=>ex, data =>datax,bkpwr=>bkpwrx, pwr=>pwrx);
l2: div25 port map (clkf=>clkx, clk25=>clk);
end Behavioral;
entity div25 is
port( clkf : in std_logic;
end;
architecture rtl of div25 is
signal count: integer range 0 to 125000;
begin
process(clkf)
begin
if (clkf'event and clkf = '1') then
if count<124999 then
count<=count+1;
else
count<= 0;
end if;
if count < 62500 then
clk25 <= '1';
else
clk25 <= '0';
end if;
end if;
end process;
end;
1 Reply
    I see you're trying to divide a clock, and use the output as a clock.
    DONT do that. generate enable signals instead and run the entire board from the source clock.
    Generating your own clocks this way is prone to timing errors that will just make things go wrong and not work properly.
