16 years agoVHDL Counter
I am new to VHDL, and I am trying to create a counter that will count up from 0 to X when a signal called enable will be true. I get errors like Latches are generated for incomplete case or if ...
16 years ago --- Quote Start --- I know I am posting in an Altera Website... I am using Xilinx ISE... It complains if it is not in the sensitivity list. Also, as I understand it, the reason why you put it in the sensitivity list is so that the "event" when any of the signals within the process(*) changes state, the process block will execute. So I would think if the enable happens to change, as it is in my case of a random signal, I need to be able to start and stop my counter. If I don't put it there, there is a chance my counter will neither stop or start its counting process. So I don't completely agree with your statement, but I have been proven wrong other times. I am not very experienced VHDL writer. I only do glue logic with CPLDS... --- Quote End --- If it is complaining, it is a bug with ISE. Nothing will happen unless there is a clock event, so having the process execute when enable changes is pointless. You only care about the state of the enable signal when there is an event on "clk". Adding extra signals to sensitivity lists reduces the performance of your code inside a simulator as it makes the simulator evaluate the process unneccesarily.
