16 years agoVHDL Counter
I am new to VHDL, and I am trying to create a counter that will count up from 0 to X when a signal called enable will be true. I get errors like Latches are generated for incomplete case or if ...
16 years agoI figured out a work around I just created a simple counter. I created a separate unit which provide a reset signal so I can reset the counters. I also made sure the counter counts only when enable is true.
This works fine
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
--Entry port
entity Counter is
generic(N: integer :=16); --Scale it to 20 bits counter
port ( clk : in STD_LOGIC;
enable : in STD_LOGIC; --Enable this counter
reset : in STD_LOGIC;
max_ticks : out STD_LOGIC;
cnts_out : out STD_LOGIC_VECTOR (N-1 downto 0));
end Counter;
architecture Behavioral of Counter is
signal r_reg: std_logic_vector (N-1 downto 0) := (others =>'0');
BEGIN
PCntr: process(clk,reset,enable)
begin
if(reset='1') then
r_reg <= (others => '0');
elsif(rising_edge(clk)) then
if(enable='1') then
r_reg <= r_reg + 1;
else
r_reg <=(others => '0');
end if;
end if;
end process PCntr;
--Output logic
max_ticks <= '1' when r_reg = (2**N-1) else '0'; --Overflow counter indicator
cnts_out <= r_reg;
end Behavioral;
