16 years agoVHDL Counter
I am new to VHDL, and I am trying to create a counter that will count up from 0 to X when a signal called enable will be true. I get errors like Latches are generated for incomplete case or if ...
16 years agoGuys,
I have modified the code you provided in an effort to get my counter to count up, and to reset it before it starts again based on the Enable signal = '1'. One thing I didn't mention is that the counter will not reach its rollover point, so I have to reset it some how before I reuse it. I am not sure the changes are correct but all the stuff I added is in RED, and comments are in green Would this work?
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity Counter is
generic(N: integer :=16); --Scale it to 20bits counter
port ( clk : in STD_LOGIC;
enable : in STD_LOGIC; --Enable this counter
reset : in STD_LOGIC;
max_ticks : out std_logic;
cnts_out : out STD_LOGIC_VECTOR (N-1 downto 0));
end Counter;
architecture Behavioral of Counter is
signal r_reg: unsigned(N-1 downto 0):= to_unsigned(0, N); --use to_unsigned function so that it works with the generic N
signal q_reg: unsigned(N-1 downto 0):= to_unsigned(0,N);
signal enable_r : std_logic; --enable register
begin
pCntr: process(clk,reset) --no need for enable in here
Variable X: integer range 0 to ((2**N)-1); -- Will this work?
begin
if(reset = '1') then
r_reg <= (others => '0');
elsif rising_edge(clk) then
if enable = '1' then
r_reg <= X + 1; --Increment - this rolls over back to 0
end if;
end if;
-- I need to start counting from zero next time I come back into the counter
-- A signal controller is toggling the enable back High/low, but the r_reg
-- will hold the previous value unless it sees a reset coming in which I don't
-- available. I am trying to clear out the r_reg so that after is sent
-- How does this change detect the edge? If I am not mistaken (bear with
-- me I am new to VHDL) it seems to me enable_r stores the state in the
-- first rising edge, since everything executes sequentially, the second time
-- in the previous state will get over-written and the if() will not fire! What
-- is the explanation of this code so I understand why this works?
--Register enable so we can detect falling edge
enable_r <= enable;
-- This code may generate the same warning since it does not have
-- the else condition on it, unless I add this...
-- if ((enable_r = '1') and (enable = '0')) then --falling edge of enable
if(enable = '0') then
cnts_out <= std_logic_vector (r_reg); --Changed to this since unsigned is different type than cnts_out right!
X := 0; --Reset the counter
else
cnts_out <= std_logic_vector(q_reg) --Does this work?
end if;
end process;
--Set an overflow Flag in due case we reach the maximum counts
max_ticks <= '1' when r_reg = (2**N-1) else '0'; --Overflow counter indicator
end Behavioral;
