16 years agoVHDL Counter
I am new to VHDL, and I am trying to create a counter that will count up from 0 to X when a signal called enable will be true. I get errors like Latches are generated for incomplete case or if ...
16 years agoLogically red:your code will work in a simulator, but wont work on an FPGA because you're trying to use the enable signal as a clock, which is not allowed.
This is a much tidier version that wont give you any warnings about latches:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity Counter is
generic(N: integer :=16); --Scale it to 20bits counter
port ( clk : in STD_LOGIC;
enable : in STD_LOGIC; --Enable this counter
reset : in STD_LOGIC;
max_ticks : out std_logic;
cnts_out : out STD_LOGIC_VECTOR (N-1 downto 0));
end Counter;
architecture Behavioral of Counter is
signal r_reg: unsigned(N-1 downto 0):= to_unsigned(0, N); --use to_unsigned function so that it works with the generic N
signal enable_r : std_logic; --enable register
begin
pCntr: process(clk,reset) --no need for enable in here
begin
if(reset = '1') then
r_reg <= (others => '0');
elsif rising_edge(clk) then
if enable = '1' then
r_reg <= r_reg + 1; --Increment - this rolls over back to 0
end if;
--Register enable so we can detect falling edge
enable_r <= enable;
if enable_r = '1' and enable = '0' then --falling edge of enable
cnts_out <= r_reg;
end if;
end if;
end process;
--Set an overflow Flag in due case we reach the maximum counts
max_ticks <= '1' when r_reg = (2**N-1) else '0'; --Overflow counter indicator
end Behavioral;
