15 years ago
VHDL code for logarithme
There are somoene that release a vhdl code for log or have any idea about it.
I need any tutorial or helps to start release it.
Thank you.
    --- Quote Start ---
    LUT is the easiest. But you should be able to generate the table using a function.
    --- Quote End ---
    I generate the LUT through Matlab. And i initialize memory with the generated data.
    --- Quote Start ---
    if you need a synthesisable version, I suggest you use a look-up table.
    --- Quote End ---
    Ok thank you, already i use LUT, but i search if it is possible to find a synthetisable code for log.
    --- Quote Start ---
    like log base 2?
    this function will return the nearest log2 of a number (but I wouldnt recommend synthesising as a real time function) Its useful for determining how many bits you need for a vector.
    function log2(x : integer) return integer is
      variable temp : integer :=x;
      variable n : integer := 1;
    begin
      while temp > 1 loop
        temp := temp/2;
        n := n + 1;
      end loop;
      return n;
    end function log2;
    --- Quote End ---
    Think you very much for your reply,
    ok for this function it is clear, but that i need is a function that can execute during a minimum of clock cycle.
    ThAnk you
    like log base 2?
    begin
      while temp > 1 loop
        temp := temp/2;
        n := n + 1;
      end loop;
      return n;
    end function log2;
