15 years agoVHDL code for logarithme
Hi, There are somoene that release a vhdl code for log or have any idea about it. I need any tutorial or helps to start release it. Thank you.
15 years ago --- Quote Start --- LUT is the easiest. But you should be able to generate the table using a function. --- Quote End --- I generate the LUT through Matlab. And i initialize memory with the generated data.
