16 years ago[vhdl] artificial neural network
I'm interested in neural networks currently :) I've written some basic ANN implementation in java with ADELINE neurons. (Actually, this is only the background of the problem) I'd like to write a simple neuron in vhdl. input vector is multiplied by weigths, result is sum. If result is > 0 then output = -1 else output = 1 And here comes the problem, I have to multiply input values by weights which are real values. I know that vhdl supports real variables but how should I use it?:confused: I tried like that but it isn't correct code --- Quote Start --- variable weigth:real; variable tmp:real; weight:=0.1; for i in 0 to inputvector'length - 1 loop tmp:=tmp+(weigth*inputvector(i)); end loop; --- Quote End --- I'd be very gradefull for any help!12 Replies
I would like to know what is difference between LAbview FPGA (it seems alos generate the code in altera) simulation and Altera simulations in Verilog or VHDL?
I have the diagram in Simulink so I have relating question --what is the most actual forums and discussion board on Simulink and especially Micro-cap, as the last one is very seldom in internet. And concerning the Microcap--could I use some conveter to or from Micro-cap to another environments such as Altera, Simulink and so on? - Altera_Forum
Concerning the latter, I have no idea. Your first question I can answer to some extend. That is, search the forum. I remember a similar question about this being asked only last week or the week before.
[edit]This was in a thread starteb by you:http://www.alteraforum.com/forum/showthread.php?t=48687[/edit]
