14 years agoVHDL array syntax
I'm just trying to test out writing out arrays in VHDL but I can't get it to work. The error I get is Error (10568): VHDL error at Testarray.vhd(16): can't write to interface object "a" of mode IN
Library ieee; USE ieee.std_logic_1164.all; ENTITY arraytest is PORT ( a : IN STD_LOGIC_VECTOR (3 downto 0); z : OUT STD_LOGIC ); END; ARCHITECTURE assignment OF arraytest is BEGIN a <= "1100"; z <= a(0) and a(1); END; Thanks.1 Reply
The problem is with line a <= "1100"
You can't assign 'a' since this is an input port, so its assignment is supposed to come from an external signal. In other words, you must instantiate this entity in a upper level and drive the a input port.
