14 years agoVHDL 2008 vs System Verilog
I have been using VHDL 2008 for several months now and like the new features of the language. In particular, I use Active-HDL and the VHDL 2008 language constructs are all fully supported. There is a...
14 years ago --- Quote Start --- Is there a point to this post? From what I have heard, better 2008 support (well, theres not alot at the moment) is coming in Q12.1, with Q12 due to hit around mid 2012, so theres going to be a bit of a wait yet. I also understand that verilog/SV has a much larger user base (all internal altera development is Verilog), hence the much greater support for it. I dont understand what you mean by your reference to "general unconstrained type"? --- Quote End --- --> To be more specific, a general unconstrained type is that which is described by Lewis and Ashendon, in "VHDL 2008 Just the New Stuff" such as on pages 103-107 is what I am talking about. I couldn't get code such as what is below to synthesize in Quartus . . . type M_unconstrained is array (natural range <>, natural range <>) of bit; type R_unconstrained is record e2 : M_unconstrained; e3 : bit; end record R_unconstrained; --- Quote Start --- IIRC, the only unconstrained things that 2008 allows are unconstrained array elements, and unconstrained definitions in a record type. From the code you posted, I dont see any 2008 features in it. It all looks 1993 compatible (apart from the process(all), which IMO allows for more lazy coding than being a useful feature) ) --- Quote End --- --> process(all) is only possible with VHDL2008 James
