16 years agovhdl -division program
hi to all if anybody having coding for division please do help me
16 years ago --- Quote Start --- it would be nice if register retiming could meet the fmax of an lpm function. --- Quote End --- In the meantime I checked this point, and I found, that the integrity of the divider IP isn't touched by the compiler/fitter. No available register is moved into the divider logic. I think it can be understood from the fact, that the divider inference doesn't provide the option to connect a clock, so it can't use the pipeline option. Regarding the suggestion to replace a division by a multiply. I'm using this in two situations: - when the divisor is a constant, as discussed above - when the divisor is a signal, but can tolerate a larger latency time than the dividend. Then 1/b can be calculated by a slow serial divider and multiplied with a in a single clock cycle. If both a and b must be processed with low latency time, it doesn't work.
