14 years ago
VGA controller
Hi! I found this VGA controller file on the net for the Altera DE2 board, and im really trying to find out how this works. I'm new to vhdl programming and have only basic knowledge when it comes to the use of different statements and operators.
questions:
1. generics:
what is the difference between generics and constants? can someone please explain how all of these integers declared in generics works (ha,hb,hc etc.)?
2. signals:
why do one use signals and how do these signals work? i.e
signal hactive, vactive: std_logic := '0'; ...etc.
3. general:
can someone please explain the general function of this program and how it works?
all answers are appreciated!
thank you!:)
vga_controller:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity vga_control is
generic (
Ha: integer := 96;
Hb: integer := 144; --beginning of hactive
Hc: integer := 784; -- end of hactive
Hd: integer := 800;
Va: integer := 2;
Vb: integer := 35; --beginning of vactive
Vc: integer := 515; --end of vactive
Vd: integer := 525);
port (
clk50M: in std_logic;
pixel_clk: buffer std_logic :='0';
hsync, vsync: buffer std_logic :='0';
red_in, green_in, blue_in: in std_logic_vector(9 downto 0);
pixel_row: buffer integer range 0 to 480;
pixel_column: buffer integer range 0 to 641;
r, g, b: out std_logic_vector(9 downto 0);
nblank, nsync: out std_logic);
end vga_control;
architecture vga of vga_control is
signal display_on: std_logic;
signal display_on_vector: std_logic_vector(9 downto 0);
-- hactive is the portion of hsync during which pixels are displayed
-- vactive is the portion of vsync during which pixels are displayed
-- display_on (display enable) must be low during retrace
begin
nblank <= '1'; -- static signal for DAC
nsync <= '0'; -- static signal for DAC
display_on <= hactive and vactive;
display_on_vector <= (others => '1') when display_on = '1' else
(others => '0');
r <= red_in and display_on_vector;
g <= green_in and display_on_vector;
b <= blue_in and display_on_vector;
--creates a 25MHz clock
process (clk50M)
begin
if (clk50M'event and clk50M = '1') then
pixel_clk <= not pixel_clk;
end if;
end process;
--horizontal signal generator
process (pixel_clk)
variable hcount: integer range 0 to Hd;
begin
if (pixel_clk'event and pixel_clk = '1') then
hcount := hcount + 1;
if (hcount = Ha) then
hsync <= '1';
elsif (hcount = Hb) then
hactive <= '1';
elsif (hcount = Hc) then
hactive <= '0';
elsif (hcount = Hd) then
hsync <= '0';
hcount := 0;
end if;
if hcount >= Hb and hcount < Hc then
pixel_column <= pixel_column + 1;
else
pixel_column <= 0;
end if;
end if;
end process;
-- vertical signal generation
process (hsync)
variable vcount: integer range 0 to Vd;
begin
if (hsync'event and hsync = '1') then
vcount := vcount + 1;
if (vcount = Va) then
vsync <= '1';
elsif (vcount = Vb) then
vactive <= '1';
elsif (vcount = Vc) then
vactive <= '0';
elsif (vcount = Vd) then
vsync <= '0';
vcount := 0;
end if;
if vcount >= Vb and vcount < Vc then
pixel_row <= pixel_row + 1;
else
pixel_row <= 0;
end if;
end if;
end process;
end;
