17 years agoVGA 25MHz, Clock 100MHz, Help!
Hi, I would like to use a 100MHz clock to drive my logic, but the problem is that VGA needs a clock of 25MHz. Right now, I am using 2 PLLs to create a 100MHz clock and 25MHz clock by us...
17 years agoclk is not vga_clk
clk is ~100MHz vga_clk ~25MHz in your design the two clocks are different ! so you must obey them and perform clock domain crossing first some verilog hints from my side within always construct use <= (non-blocking assignment) instead of = (blocking assignment) second, the compare "vga_y == 0" is correct s long as vga_y is 1 bit wide. if it is an array better use === you will waste lot of time hunting such a bug when using == with arrrays so your code a bit shorted always @ ( posedge clk ) counter <= counter + 1; and always @ ( posedge clk ) vga_color <= counter shows one problem. counter is based on a different clock that vga_color, so you could get some glitches and oll other problems. the synchronisation is exactly described by the quartus online help, but it says something like taht for your problem reg [31:0] counter_piped1; reg [31:0] counter_piped2; always @ ( posedge vga_clk) begin counter_piped1 <= counter; counter_piped2 <= counter_piped1; end (you recognized the 2 DFF here both 32bit wide ?) now counter_piped2 is syncron with vga_clk always @ ( posedge vga_clk) vga_color <= counter_piped2;
