11 years agoVery low speed of HPS after Preloader
I try insert next code for Altera examples in main(): volatile int i; for (i = 0; i < 800*1000*1000; i++) ; In SDRAM-variant work is greater than 2 min, in HelloWorld for FFFF0000-addresses ...
11 years agoIn cv_5v4.pdf ("Cyclone V Device Handbook Volume 3: Hard Processor System Technical Reference") is subsection cv_54002: "Clock Manager", and writed:
--- Quote Start --- The Clock Manager offers the following features: • Generates and manages clocks in the HPS • Contains the following PLL clock groups: - Main—contains clocks for the Cortex-A9 microprocessor unit (MPU) subsystem, level 3 (L3) interconnect, level 4 (L4) peripheral bus, and debug - Peripheral—contains clocks for PLL-driven peripherals - SDRAM—contains clocks for the SDRAM subsystem ... --- Quote End --- In example Altera-SoCFPGA-HardwareLib-ClockManager-CV-GNU to console is outed 25 MHz for HPS and other, I try use the code: my_chk(); {
uint32_t mu, di;
status = alt_clk_pll_vco_cfg_get(ALT_CLK_MAIN_PLL, &mu, &di);
if (status == ALT_E_SUCCESS) {
status = alt_clk_pll_vco_cfg_set(ALT_CLK_MAIN_PLL, mu*2, di);
my_chk();
} to increase speed of HPS, however call of alt_clk_pll_vco_cfg_set() return error ! And what is more -- call of "alt_clk_pll_vco_cfg_set(ALT_CLK_MAIN_PLL,mu,di);" (without "*2") also return error ! Mistake is in alt_clock_manager.c, function 'alt_clk_pll_vco_chg_methods_get(pll, mult, div);", lines: temp = mult * (inputfreq / div);
if ((temp <= freqmax) && (temp >= freqmin)) // are the final values within frequency limits? The same values that I read -- not may be written to Clock Manager back ! I has installed last version of updates to SoC EDS 14.0. If I use "mu/2" as new multiplier, the alt_clk_pll_vco_cfg_set() call is successful, test "my_chk();" works slightly slower. Use anybody alt_clock_manager.c interface to change main PLL clocks ?
