15 years agoverilog: mux not returning expected output
Hi everyone,
This is my first post, just recently started verilog, so be nice :). For some reason my I am not getting my expected output. I think it has to do with yMux producing 2-bits and my I'm expecting a 1-bit output. (Look below) mainModule
module mainModule;
// Registers
reg flag;
reg a, b;
reg tem;
reg c;
reg expect;
// Wires
wire z;
// Instantiation
defparam my_mux.SIZE = 32;
yMux my_mux(z, a, b, c);
initial
begin
repeat (3)
begin
a = $random;
b = $random;
c = $random % 2;
# 1;
assign tem = (((~ c) & a) | ( c & b));
$display("z---->%b", z);
$display("eval->%b", tem);
expect = (tem === z) ? 1 : 0; //#1;
$display("a:%b, \nb:%b, \nc:%b \n", a, b, c);
if (expect === 1)
$display("PASS, z->%b", expect, z);
else
$display("FAIL, z->%b", expect, z);
$display("---------------------------------------------");
end
$finish;
end
endmodule
yMux
module yMux(z, a, b, c);
parameter SIZE = 2;
output z;
input a, b;
input c;
yMux1 mine (z, a, b, c);
endmodule
yMux1
module yMux1(z, a, b, c);
output z;
input a, b, c;
wire notC, upper, lower;
not my_not(notC, c);
and upperAnd(upper, a, notC);
and lowerAnd(lower, c, b);
or my_or(z, upper, lower);
endmodule
So in the mainModule I create a register called tem to test and see if it equals z, the output of yMux. But for some reason it sometimes FAILS and SOMETIMES PASSES!! HERE's a sample output: z---->11000000100010010101111010000001 tem->00010010000101010011010100100101 a:00010010000101010011010100100100, b:11000000100010010101111010000001, c:1 FAIL, z->03230228097 --------------------------------------------- Clearly we see that z is not equal to tem?? But why is that!!??No RepliesBe the first to reply
