16 years agoVerilog Help
Hey Guyz! I need some help with verilog coding. i got this code off opencore website that teaches us how to code a sd card controller.Below shows 2 of the verilog file. A) spiMaster_defin...
16 years agoFrom the name, the first file appears to contain definitions for constants. The code you listed in 'A' defines two constants which are dependant on whether or not SIM_COMPILE is defined. If SIM_COMPILE is defined, SD_INIT_START_SEQ_LEN will be an 8 bit value of '3'. If SIM_COMPILE is not defined, SD_INIT_START_SEQ_LEN will be hex 'a0'.
