17 years agoVerilog FSM not working on FPGA
Hi, Please accept my appologies if I have posted this is the incorrect place, but im new to this and this post seems kind of relevant. I am trying to create a format for my FSM, To...
17 years agoThans Harald,
I understand what you mean now. I am currently triggering the calculation of next_state at every posedge of clock, ready for the state register to be updated on the negedge of the clock. This does seem to work correclty when synthsised on FPGA. Would it be better to do this combinationally? Also if possible could you explain further as to why I cannot write... //State actions always @(state) begin case(state) S0: begin clk_out = 1'b1; count = 4'b0000; end S1: clk_out = 1'd1; S2: begin count <= (count + 1'b1); clk_out = 1'b1; end The count does not work correctly, but my understanding of the Verilog is that, whenever state changes value, the construct would be run once. This should update the count register once. And so why is this not possible? Thanks so much for your help in this matter Paul Below is the current working code with all the constructs executed on a clk edge: module Clock_Gen(rst_n, clk_out, clk_in, count); //Input Ports input rst_n; input clk_in; //**************************************************** //Output Ports output [3:0] count; output clk_out; //**************************************************** //Output Registers reg clk_out; //**************************************************** //Internal Registers reg [40:0] count; //**************************************************** //State Definition parameter S0 = 4'd0, S1 = 4'd1, S2 = 4'd2, S3 = 4'd3, S4 = 4'd4, S5 = 4'd5, S6 = 4'd6; //**************************************************** //Internal state variables reg [3:0] state; reg [3:0] next_state; //**************************************************** //Set initial reg values //**************************************************** //State changes only at positive edge of clock (synchronous) always @(negedge clk_in) if (!rst_n) state <= S0; else state <= next_state; //State Change //**************************************************** //State actions always @(posedge clk_in) begin case(state) S0: begin clk_out = 1'b1; count = 25000000; end S1: clk_out = 1'd1; S2: begin count <= (count - 1); clk_out = 1'b1; end S3: begin clk_out = 1'b0; count = 25000000; end S4: clk_out = 1'b0; S5: begin clk_out = 1'b0; count <= (count - 1); end endcase end //**************************************************** //State machine using case statement always @(posedge clk_in) begin case(state) S0: next_state = S1; S1: begin if (count == 0) next_state = S3; else next_state = S2; end S2: next_state = S1; S3: next_state = S4; S4: begin if (count == 0) next_state = S0; else next_state = S5; end S5: next_state = S4; endcase end endmodule
