16 years agoVerify problem while runing on Nios II hardware
Hi there, when i try to run my project on the Nios II hardware i get the following problem: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Processor is already paused Readi...
16 years agocheck in pin planner, positions of
1 reset 2 clock check in system library properties that you are using on chip memory as program memory
