16 years agoVerify problem while runing on Nios II hardware
Hi there, when i try to run my project on the Nios II hardware i get the following problem: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Processor is already paused Readi...
16 years agoCheck your timings, both in SOPC builder for the SRAM and in Timequest when you compile the Quartus project.
You can also compile a memory test example, run it from the on-chip memory and have it test the SRAM.
