17 years agoVerify failed between address SSRAM
After downloading code in NIOS IDE, the verification of this code is always failing. My system is very easy, NIOS + On chip RAM + SSRAM + FLASH, I'm using starter kit CycloneIII. I've tri...
17 years agoStart a new "memory test" project. Have it run from on-chip memory and test the sram. It should help you find what the problem is.
