16 years agoVerify failed ---Leaving target processor paused
While programming flash with 1.2 Mb file I get error --- Programmed 1074KB +78KB in 23.1s (49.8KB/s) Verify failed at offset 60000 Verify failed at offset 80000 Verify fai...
16 years ago@mchmitt
actually, i have sram, ethernet, sdram, timer, and some PIOs in my hardware image, along with flash (attached to NIOS). I place that image inside FPGA (sof) before running flash programmer. I checked for timings, i found them to be correct. (this gives rise to one more doubt of mine, that if timings were wrong, then would memtest fail or pass? )
