16 years agoVerify failed ---Leaving target processor paused
While programming flash with 1.2 Mb file I get error --- Programmed 1074KB +78KB in 23.1s (49.8KB/s) Verify failed at offset 60000 Verify failed at offset 80000 Verify fai...
16 years agoDid you check that your nios processor is connected correctly to your external memory in your top level module?
When writing the nios processor does not know he is not writing in exisiting memory, but when reading/verifying no data is uploaded.
