16 years agoVccio level for LVDS IOs
Hi, AN479 says that LVDS ip & op must be powered with a 2.5V Vccio except: all LVDS inputs for cyclone device are powered by Vccint. The PCB with a cyclone was designed for other purpo...
16 years agoAN479 also tells:
--- Quote Start --- Supplying higher than supported voltage to VCCIO for LVDS would violate the rated specifications and may possibly damage the buffer. --- Quote End --- Apart from this, operating Cyclone at VCCIO of 3.3V with standard 3R network for LVDS output results in an incorrect common mode level, although it possibly works at lower rates. A 5R network with additional pull-down resistors could achieve correct LVDS levels.
