16 years agoVariable Frequency of clk
i have a design that require to run on variable frequency of clk(sampling rate), in the range of 8kHz to 216kHz. My question are: 1. How to write the sdc? 2. Other than sdc, is there any ...
16 years agoUsing a divided clock is usually unsuitable, particularly because crossing timing domains can cause timing violations. But if all design logic, except for the clock divider, is run at the divided frequency, in other words, no signal is crossing the timing domains, the analysis is trivial.
You may want to start with the classical timing analyser and specify the input frequency to the clock divider. As long as there are no external inputs or outputs, that need to be constrained, this should be sufficient.
