16 years agoVariable Frequency of clk
i have a design that require to run on variable frequency of clk(sampling rate), in the range of 8kHz to 216kHz. My question are: 1. How to write the sdc? 2. Other than sdc, is there any ...
16 years agoThe suggestion is to use a fixed system clock (e.g. 50 MHz) and a variable rate clock enable. The timing requirements don't change with the clock enable rate.
