16 years agoVariable Frequency of clk
i have a design that require to run on variable frequency of clk(sampling rate), in the range of 8kHz to 216kHz. My question are: 1. How to write the sdc? 2. Other than sdc, is there any ...
16 years agoI would expect the "variable frequency" sampling clock implemented as a synchronous clock enable, generated by a clock divider. In this case, no additional timing constraints are involved, because the timing is completey based on the system clock.
