USing VCS RTL Simulation from quartus pro generated code
HI , this is my answer
Have you Generate the Simulator Setup Script in the document section 2.5.3.2.1. ?
--> YES
SEE second screen shots
1) scripts result are not same as
Intel Quartus Prime Pro Edition User Guide: Third-party Simulation
2) Without ignore comments in script,
cmd> source vcs_setup.sh
should be working. but not.
3) Can I get simple example such as only 1 PLL design for VCS RTL simulation .
to see waveform ( generated FSDB )
I think you are using the incorrect command.
Try using sh vcsmx_setup.sh instead.
source vcsmx_setup.sh is for sourcing the Synopsys VCS MX Simulator Setup Scripts.
Go through the Questa Quick Start then you will understand the simulation flow.
- minjoolee4 years ago
HI,
I thinks that we are not same page.
Can you see attachment from Quartus pro
Just generated one PLL which name is test.
In there, there are script for vcs_mx.
1) Script said
source ~~~~~~/vcsmx_setup.sh
--> NOT WORKING ( My problem to run simulation)
2) The template is not said as
Even same Quartus prime pro version as doc,
Why generated script file contents is not same?
Would check it again?
- RichardT_altera4 years ago
For those who come across similar issue:
To run simulation on the design:
- Go to synopsys/vcsmx
- Type sh vcsmx_sim.sh
- A DVE gui will popup:
- Click on Simulator> Setup, change the Simulator argument to -ucligui and Click OK
- After that, click on Signals>Add to waves >New wave view to generate waveform window
- Click on the Start/Continue (F5) –see the circled arrow to run the simulation
- The simulation will run till finish with the waveform is updated with the signals in the tb as shown below
With that, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
