Using third party QSPI flashs as configuration memory
I checked the documentation of the generic serial flash interface and found a footnote (1) on page 3:
(1) The supported flash devices for configuration memory are, EPCQ, EPCQ-A, EPCQ-L, and
Micron* MT25Q (256Mb to 2Gb) devices
Do you think it make eense to try anyway ?
In my project, the initial programming of QSPI flash is done by JTAG
Hum indeed... I think that those memories are the ones you can natively select in the Quartus Convert Programming files tool (the one to convert sof to jic for instance). However, starting Quartus 19 I believe (not sure of the actual version), you can instruct the tool how to deal with other Flash memories.
Otherwise, if you are using JTAG for Flash programming and do not need Flash access after configuration, I do not think you have to use the ASMI or GSFI IPs.
When you JTAG-program a JIC file to a Flash device with Quartus Programmer, it can first load a "SFL design" in the FPGA as a bridge to the Flash. As I mentioned, you can instruct the tool how to correctly address your flash device (see https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-gen-flash-programmer.pdf).
For instance, I could do this technique to write JIC file to a third party Flash memory. I just could not configure the FPGA in AS mode, because my Flash was unfortunately not one of the Intel Supported Third Party Configuration Devices for my FPGA (while yours is).
