11 years agousing the same .pof file with different package MAX2 cplds
hi, I have a .pof file for max2 CPLD with 256 pins: epm1270m256. I want to use the same .pof file with a similar CPLD but with a different package : epm1270f256. is this possible? I successful...
11 years agoThere is no issue programming the .pof file between epm1270m256 and epm1270f256 since the IDCODE is the same. Typically the device performance should not be depending on the device packaging whether MBGA or FBGA type. Unless if you are using a different speed grade then this might affect the timing performance. You can refer to this link:
https://www.altera.com/support/support-resources/knowledge-base/solutions/rd06282006_507.html
