10 years agoUsing schematic
Hi all, I've just tried for the very first time to use a CPLD and am having problems with transfering a schematic to the CPLD.
Can anyone explain why my schematic has errors on the pinouts Warning (20028): Parallel compilation is not licensed and has been disabled Warning (10034): Output port "D0" at test.v(36) has no driver Warning (10034): Output port "D1" at test.v(37) has no driver Warning (10034): Output port "D2" at test.v(38) has no driver Warning (10034): Output port "D3" at test.v(39) has no driver Warning (13024): Output pins are stuck at VCC or GND Warning (13410): Pin "D0" is stuck at GND Warning (13410): Pin "D1" is stuck at GND Warning (13410): Pin "D2" is stuck at GND Warning (13410): Pin "D3" is stuck at GND Warning (21074): Design contains 5 input pin(s) that do not drive logic Warning (15610): No output dependent on input pin "CLK" Warning (15610): No output dependent on input pin "CLR" Warning (15610): No output dependent on input pin "DATA" Warning (15610): No output dependent on input pin "LATCH" Warning (15610): No output dependent on input pin "SEL" Warning (20028): Parallel compilation is not licensed and has been disabled Warning (292013): Feature LogicLock is only available with a valid subscription license. You can purchase a software subscription to gain full access to this feature. Warning (169140): Reserve pin assignment ignored because of existing pin with name "CLK" Warning (169140): Reserve pin assignment ignored because of existing pin with name "CLR" Warning (169140): Reserve pin assignment ignored because of existing pin with name "D0" Warning (169140): Reserve pin assignment ignored because of existing pin with name "D1" Warning (169140): Reserve pin assignment ignored because of existing pin with name "D2" Warning (169140): Reserve pin assignment ignored because of existing pin with name "D3" Warning (169140): Reserve pin assignment ignored because of existing pin with name "DATA" Warning (169140): Reserve pin assignment ignored because of existing pin with name "LATCH" Warning (169140): Reserve pin assignment ignored because of existing pin with name "SEL" ThanksNo RepliesBe the first to reply
