syuanyou
2 years agoUsing ghrd.v setting GPIO question
Hi, I am using ghrd.v to setting project gpio for a while. It work correct before, but someday I found I couldn't replace gpio. For example, I tried to replace a pin from gpio[2] to gpio[19], comp...
syuanyou
2 years agoHi,
The problem still exist. The other GPIO pins have the same problem. I replaced the GPIO in the pin planner with a new variable and reconnected, but it didn't improve the issue. I also tested it using SignalTap, and the GPIO operation on SignalTap is working correctly, just like the settings in GHRD.
Thank you
