syuanyou
2 years agoUsing ghrd.v setting GPIO question
Hi, I am using ghrd.v to setting project gpio for a while. It work correct before, but someday I found I couldn't replace gpio. For example, I tried to replace a pin from gpio[2] to gpio[19], comp...
sstrell
2 years agoCan you show your code? Did you make the change in the Pin Planner? More details needed.
