18 years agoUsing CRC detection with standalone FPGA
Hello, I'm planning a board with a standalone Stratis II FPGA. Since I have no external CPU on the board, I plan to use a EPCS device to configure the FPGA in AS mode. I want to employ the r...
18 years agoSo you recommend an external open-drain logic, something like an open-drain buffer fed from '0' connected to nCONFIG, with CRC_ERROR serving as its enable with a pulldown ?
This way when CRC_ERROR is: * 'Z' during FPGA configuration and initialization: pulldown makes driver disabled and nConfig isn't affected * '0' when everything is normal during operation: same as above * '1' when an error is detected: the buffer is enabled and transfers '0' to nCONFIG, which triggers FPGA reconfig, which in turn makes CRC_ERROR 'Z' again and closes the buffer. Sounds reasonable ?
