12 years agoUsing CPLDs as a dedicated DDC
Hi, The have an ADC sampling at 37.4MSps and I want to fed this data into a DSP for real-time baseband processing. However, I need an interface between the ADC and DSP to digitally down convert...
12 years ago --- Quote Start --- I would like decide on a FPGA family and size for this. --- Quote End --- I think a Cyclone IV would probably work. The resources required depend on your ADC bit-width and the stop-band rejection you need to achieve, since that determines the multiplier bit-width. --- Quote Start --- I had FDAtool simulating a few different filter designs. As you discussed, if I used a decimate-by-4 filter it would requires 44 coefficients. Is there a method that relates the filter coefficients to the FPGA resources required? --- Quote End --- It depends on the filter structure. Given that your decimated data rate is a lot lower than your FPGA clock rate, fewer than 44 multipliers will be used. Altera has an FIR compiler that you can try to use, otherwise try and implement a few filters yourself. You can always get one example working, use that to select the FPGA, and then "optimize" the implementation later. Cheers, Dave
