12 years agoUsing CPLDs as a dedicated DDC
Hi, The have an ADC sampling at 37.4MSps and I want to fed this data into a DSP for real-time baseband processing. However, I need an interface between the ADC and DSP to digitally down convert...
12 years agoGreat examples! and thanks for the references.
I like the idea of implementing all DDC DSP in a FPGA ie complex-valued baseband (mixing fs/4 = 9.35MHz) and decimation filter (by 4). I would like decide on a FPGA family and size for this. I had FDAtool simulating a few different filter designs. As you discussed, if I used a decimate-by-4 filter it would requires 44 coefficients. Is there a method that relates the filter coefficients to the FPGA resources required? Cheers, Les.
