18 years agoUsing CPLD/FPGA as a Timer
Hi. I am interested to implement a timer that can count up to hours, in my FPGA/CPLD. The main purpose of the timer is to issue a pulse after a certain fixed duration, eg. every 2 hours. Normal...
18 years agoHello,
I just was aware, that the said MAX_COUNT overflows the integer range, thus my example is incorrect. Changing the count value to unsigned with full length, the LE consumption increases to 54. Sorry for the confusion. Frank-- Modified Quartus II VHDL Template
-- Binary Counter
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity timer is
generic
MAX_COUNT : unsigned(35 downto 0) := x"861C467FF"
port
clk : in std_logic;
reset : in std_logic;
enable : in std_logic;
q : out std_logic
end entity;
architecture rtl of timer is
begin
process (clk)
variable cnt : unsigned(35 downto 0);
begin
if (rising_edge(clk)) then
if reset = '1' then
-- Reset the counter
cnt := (others => '0');
q <= '0';
elsif enable = '1' then
-- Increment the counter if counting is enabled
if cnt < MAX_COUNT then
cnt := cnt + 1;
q <= '0';
else
q <= '1';
end if;
end if;
end if;
end process;
end rtl; P.S.: Rounding MAX_COUNT to x"860000000", the LE consumption decreases to 41
