18 years agoUsing CPLD/FPGA as a Timer
Hi. I am interested to implement a timer that can count up to hours, in my FPGA/CPLD. The main purpose of the timer is to issue a pulse after a certain fixed duration, eg. every 2 hours. Normal...
18 years agoHello,
basically, the simple fact that the system needs (2*3600*5e6) states can't be bypassed. ceil(log2((2*3600*5e6)-1)) = 36 gives the number of bits for a binary counter, which is always the minimal state representation, I think. Using a modified vhdl binary counter template with a MAX II CPLD, I got an overall LE consumption of 46. The 10 additional LE's are a tribute to the particular MAX_COUNT, a 2**N value would allow a simple ripple-carry counter. Best regards and Happy New Year! Frank-- Modified Quartus II VHDL Template
-- Binary Counter
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity timer is
generic
MIN_COUNT : natural := 0;
MAX_COUNT : natural := (5e6*3600*2)-1
port
clk : in std_logic;
reset : in std_logic;
enable : in std_logic;
q : out std_logic
end entity;
architecture rtl of timer is
begin
process (clk)
variable cnt : integer range MIN_COUNT to MAX_COUNT;
begin
if (rising_edge(clk)) then
if reset = '1' then
-- Reset the counter
cnt := MIN_COUNT;
q <= '0';
elsif enable = '1' then
-- Increment the counter if counting is enabled
if cnt < MAX_COUNT then
cnt := cnt + 1;
q <= '0';
else
cnt:=MIN_COUNT;
q <= '1';
end if;
end if;
end if;
end process;
end rtl;
