10 years agoUsing both SDRAM of DE2-115
I've read that the DE2-115 board has two SDRAM chips.. I've used one of this (sdram_control_4port) to store the odd and even lines of the tv decoder i've used using Verilog. My problem now is that i need another storage for the processing of my image and i dont know how i can use the other SDRAM. Can anyone help me with this? Thank you in advance.
1 Reply
The two devices share all their control signals (with the exception of their data mask 'DQM' signals). So, the two SDRAM devices are always accessed together.
There is a 32-bit data bus split across the two devices - 16-bits per device. Use of the data mask could result in 1, 2, 3 or 4 bytes being written/read during any single access. How wide is the data bus that you're currently using? Are you sure you've only "used one"? Cheers, Alex
