14 years agoUsing ALTPLL and ALTCLKCTRL (Clock Muxing)
I have 3 clocks that I want to select which clock to use for a certain part of my subsystem. 2 clocks are generated from the internal PLL and one is a external clock source. Although the conce...
14 years agoIf you turn to the help on ALTCLKCTRL in Quartus II, you'll see there are some restrictions in connecting the input ports to different clock sources.
inclk[0] and inclk[1] need to be driven by clock pins and inclk[2] and inclk[3] need to be driven by a PLL clock output. So in your case, you need to instantiate a ALTCLKCTRL with four input ports: inclk0x, inclk1x, inclk2x and inclk3x. Connect inclk2x to temp_c0, inclk3x to temp_c1, inclk0x to clk. Connect inclk1x to '0'. Then you will pass the compilation :)
