11 years agoUsing Altera GPIO Lite Ip core as bidirectional DDR
Hi, I have a signal whose data rate is 480Mbps. it is a DDR signal. I would like to know whether by using GPIO Ip i can acheive this ?. What would be the IO standard for the ddr output of GPIO...
11 years agoHie Sujesh,
just to addon. Like what Alex mentioned, it's not very common to use 1.2V LVCMOS I/O standard for DDR-related applications, =) However Quartus does not set restrictions based on the "common applications" of the I/O standards. Since you are new, i recommend you to checkout the Altera web which has a tonne of documentation on many topics that would be helpful to you. e.g.: https://www.altera.com/en_us/pdfs/literature/an/an348.pdf this should be a good guide for you on DDR-related applications, =) thanks, have a nice day!
