14 years agoUsing a tcl script to assign pins
Is it possible to use a tcl script file to make I/O pin assignments instead of using the Pin Planner? I tried doing that with a script file such as the following: package require ::...
14 years agoIs it possible to get a copy of the pin extraction utility you're using josyb?
