14 years agoUsing a tcl script to assign pins
Is it possible to use a tcl script file to make I/O pin assignments instead of using the Pin Planner? I tried doing that with a script file such as the following: package require ::...
14 years ago --- Quote Start --- I did generate the Tcl file for an implemented project and the statements in my example script are of the same form as in generated file, I just stripped out a lot of stuff that didn't appear to be necessary to just set the pin assignments. --- Quote End --- I guess you cut out something that was necessary :) --- Quote Start --- The implemented project was for a Max II whereas the current project is for a Cyclone II. I assumed the formats would be the same. Is that correct? --- Quote End --- Pin assignments are the same. There are a few other settings that have slightly different names, I forget what they are, I usually just 'generate' a Tcl file for a project when I'm done, and check that I have all the non-default values copied into my custom Tcl scripts. Cheers, Dave
