14 years agoUsing a tcl script to assign pins
Is it possible to use a tcl script file to make I/O pin assignments instead of using the Pin Planner? I tried doing that with a script file such as the following: package require ::...
14 years ago --- Quote Start --- Is it possible to use a tcl script file to make I/O pin assignments instead of using the Pin Planner? --- Quote End --- Yes. I've posted plenty of examples that contain scripts. This tutorial has the scripts for several boards: http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial --- Quote Start --- I tried doing that with a script file such as the following: package require ::quartus::project set_location_assignment PIN_B13 -to mode set_location_assignment PIN_L1 -to clk # etc... export_assignments but that generated a lot of errors when my file was run from the Tcl Scripts dialog box. --- Quote End --- Open up a design that has pin assignments already implemented, and use "Project->Generate Tcl File For Project" to see the correct syntax. The syntax is a little verbose. In the scripts I create (key,value) pairs for pin assignments, and then loop over them and convert them to Altera synthesis directives. Its a little more complicated to understand the first time you read the script, however, creating the script is a lot easier for the next board. Read the scripts and ask questions. Cheers, Dave
